NI TestStand
Do I need to use a LabVIEW OI with TestStand?
Hi All,
I'm working on a project which uses LV code modules within TestStand. It's been a while since I took my TestStand courses, and I never really used it in the interim.
When deploying a TestStand Sequence, do I need to use an OI? (like the examples provided) Or will I be able to run the TestStand sequence on the target machine itself, with just a generic OI?
I hope this makes sense!
(921 Views)
You can use any of the OIs that ship with TestStand.  Or any that you create.  The OI should be irrelevant to your sequence file and code modules.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(887 Views)
