04-30-2008 09:32 AM
05-01-2008 06:20 PM
05-02-2008 12:07 AM
05-02-2008 12:49 AM
Where is the array held, is it part of the custom step SetEngine Speed or is it in your Sequence / Sequence File as a Local/Parameter/FileGlobal.
If it part of the custom step, what step properties do you have to define?
Does the Array start empty or is it set to a fix size?
Regards
Ray Farmer
