NI TestStand
Do you want to save the sequence
There must be a way to not be prompted each time a sequence is edited then run using  TS 2016.
(2,019 Views)
Accepted by topic author richjoh
Go to Configure >> Sequence Editor Options >> Save Before Running
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,930 Views)
