NI TestStand
Doclick Hangs Preload of Squence file & Labview
I use "DoClick" Method  to  Trigger an Entry Point   thr´ a Boolean  Control.
The  DoClick hangs Labview  for my Sequence file.  (with many VI's Database connectivity...)
The doclick functions without problem for  example Teststand Seq files from NI  .
Also my Seq file works  perfectly with the   Entry point  Activex  Buttons on  Simple  UI
any suggestions!!
Message 1 of 9
(5,339 Views)
What are you doing in your DoClick method?
-Doug
Message 2 of 9
(5,321 Views)
I just  instatiate the DoClick method
like in the  png file.
and as mentioned it works  for all seq files (example & otjer  simple ones)
Message 3 of 9
(5,318 Views)
Hey akshay2008,
I don't think your png attachment got added to the forum post. Could you try adding it again?
Message 4 of 9
(5,310 Views)
Thanks fpr the response Daniel
I will put that tomorrow as soon as i am in Office
its 8 PM in Germany now!
regards
akshay
Message 5 of 9
(5,307 Views)
Message 6 of 9
(5,297 Views)
hi there
the issue with doclick is still there
has anyone  faced similar issues
Message 7 of 9
(5,192 Views)
WHat does that mean? Do the LV modules fail to run? What does TS during that time?
What are your settings for the LV adapter in TS?
Does this happen with the UI running as source code only or even if it is running as EXE?
Norbert
Norbert
Expert: Geometry
Message 8 of 9
(5,188 Views)
thanku all,
well the issue was sloved
I changed the  Load option for the seq file to "load dynamically"
previously it was "preload when execution begins"
Message 9 of 9
(5,138 Views)
