NI TestStand
Does NI has support to portuguese language ?
I'm trying to translate the messages from English (default) to portuguese on TestStand.
My question is: Is There something already done or should I start from scratch ??
If the answer is "no, you should translate yourself", what are the correct files ??
Thanks in advanced.
Giuliano
(2,899 Views)
Hello Giuliano,
TestStand does not support portuguese by default but you can always translate and create your own language files for TestStand. The folder that contains the language files is:
C:\Program Files\National Instruments\TestStand 3.x\Components\NI\Language
By default it has English language folder and you can use the files from that folder to start translation.
I hope it helps,
Rajiv G
(2,881 Views)
