NI TestStand
Does TestStand support two sub-sequences running at same time
Hi everyone:
    There are two sub-sequences whose pre-conditions is same, that is, they may run at same time. Just liking two threads, if a time trigger occurs, two  thread will run.
thanks a lot!
(2,846 Views)
MotionBoy,
sure you can. Just configure your calling steps from the subsequence to "New thread".
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,844 Views)
