NI TestStand
Does Win 7 Ultimate SP1(64-bit) entirely support TS 2010 SP1 + LV 2011 SP1?
    In NI TestStand 2010 SP1 Release Notes, it points out we could use "Windows 7 Service Pack 1 (32-bit and 64-bit), including Starter Edition" with TS 2010 SP1.
    Does it mean that any editions of Win 7 SP1 could support TS 2010 SP1, or just Starter Edition?
    Win 7 Ultimate SP1(64-bit) is installed in my computer. In a sequence file, I insert a dialog vi into PreUUT. When the sequence is in progress, the front panel will pop-up, but which couldn't response to user's actions normally. As shown in the figure.
 A dialog vi
   Tks for your reply.
(3,967 Views)
Win 7 64-bit is fully supported.
You need to close the VI front panel before executing your sequence.
CTA, CLA, MTFBWY
(3,960 Views)
Surely I have closed the VI front panel.
However any VI I have inserted into PreUUT, the problem will continue to exist.  The VI doesn't work rightly.
This problem doesn't occur on another machine with Windows7 32-bit.
Strangely enough!
Tks for your reply.
(3,954 Views)
The following link may help if you are using 64 bit LabVIEW:
http://digital.ni.com/public.nsf/allkb/4AB63B9B0EFA23D28625761D0053B8B0
Jim
(3,947 Views)
Tks for your reply.
I didn't write clearly that LabVIEW in my computer is 32-bit version.
(3,935 Views)
