NI TestStand
Don't display skip step in test report
I am new to teststand! I don't how to do config the report. I don;t want to display the skip steps in test report! Who can help me !
(4,086 Views)
Prior to TestStand 2012 here are the instructions.  Go to Configure -> Report Options.  Select the 'Contents' tab and find the ring control next to the Result Filtering Expression.  When you select the pulldown arrow, there are four default selections.   To discard any skipped steps add the following:
Result.Status != "Skipped"
The above steps work if the report is HTML or Text.  It seems to be disabled for XML and ATML report generation.
PH
(4,083 Views)
Note this option is not available for the XML report format.  to accomplish this in an XML report, you would need to modify the stylesheet, as in the example here:
https://www.ni.com/docs/en-US/bundle/teststand/page/excluding-results-from-an-xml-report-based-on.ht...
However, it appears you are using HTML, so this should not be an issue.
Also, the instructions Teds and I provided are also valid for TestStand 2012.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(4,071 Views)
