NI TestStand
Don't remember last user
Usually the teststand 3.1user interface login window comes up with the user name from the last login. How to make that entry empty as default ?
(2,975 Views)
Accepted by topic author markus kossmann
HI,
You have to change the VI to display an empty string instead of the last login name.
With this example you have to overwrite the FrontEndCallback which creates the user interface. For example you also could overwrite the Sequence file load callback with this sequence.
(then you have to take care of the paramters because at this point they are not already present).
I hope this can help you.
Best Regards
Regina
AE Germany
(2,964 Views)
