NI TestStand
Double \\ passing Path to LV
Hi, I have to pass some path from TS to LV. I have always used the double slash \\. Is possible to use only one "\"? If I do it the string that LV gets is different from the original. I know that the "\" is a special character and the behavior depends of the following character.
Thanks all
(4,166 Views)
Accepted by topic author logatto
Not sure why you are asking this as you already know the answer.
I surpose you could send an array of U8's rather than a string then in LabVIEW convert your array back to a string.
Regards
Ray Farmer
(4,153 Views)
I agree with Ray. You should send a code and then convert it to a charachter in LabVIEW.
Bye!
MarcoMar
National Instruments Italy
(4,148 Views)
Thanks guys.
(4,140 Views)
If your path is stored in a string variable you don't need double backslashes, you only need double backslashes if you have a string literal in an expression.
-Doug
(4,124 Views)
