NI TestStand
During deploying,it said DAQmx driver need installed
During deploying,it said DAQmx driver need installed, but i do not want to install DAQ driver and develop DAQ program ,how can I do?
(3,906 Views)
During Deployment of what!
Please give version numbers of the applications you are using.
Regards
Ray Farmer
Message Edited by Ray Farmer on 02-26-2009 06:33 AM
Regards
Ray Farmer
(3,901 Views)
I use teststand 4.0.1,see the error message from below jpg attached:
(3,896 Views)
What options have you selected in the Installer Options?
Regards
Ray Farmer
Regards
Ray Farmer
(3,892 Views)
I use default options,see  below jpg.
(3,889 Views)
That is strange! Doesn't look like any of the options you have enabled require DAQmx8.6.
What happens when you enable the DAQmx8.6 control, do you still get the prompt?
Regards
Ray Farmer
Regards
Ray Farmer
(3,877 Views)
Hi ttagiio,
This is somewhat confusing, but it's working as designed and it is NOT pulling in all of DAQmx.  The reason is that NI software is highly componentized, and many of the same underlying system components are shared among different NI products.  Note that it's just asking for the DAQmx CD (this version of TS doesn't tell you what it actually needs from the CD) -- so it likely is needing that specific version of some system components that happen to be on the DAQmx CD.
Please see the following thread and KB for a more detailed explanation:
http://forums.ni.com/ni/board/message?board.id=180&thread.id=38917&view=by_date_ascending&page=1
http://digital.ni.com/public.nsf/allkb/C3666BA408F81E59862570D20056E692?OpenDocument
- WesW / NI
Message Edited by WesW on 02-26-2009 11:23 AM
(3,862 Views)
