NI TestStand
Dynamically creating sequence file
Can I create a test stand sequence file through my own program which
uses Test stand on the back end as a activeX server?
Or can I dynamically add test steps to an existing test sequence?
vishi
(3,044 Views)
Hi Vishi,
Adding steps to an existing test sequence, there are examples at
http://zone.ni.com/devzone/devzone.nsf/webcategories/0195DDBE3C3B6F0A862567B3006BED4E?opendocument&node=DZ52238_US
Creating Sequencefile look at the examples here
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E03456A4E034080020E74861&p_node=DZ52241&p_source=external
Hope these get you started
Ray Farmer
Regards
Ray Farmer
(3,044 Views)
