NI TestStand
ERROR 17306
HI, Everyone. I am using the labview TestStand 2017, a 17306 error window pop-up when i am running the execution file. What are the possible reason of this error. How to resolve. Looking forward to community valueable responses. If I run any sequence from the build or modify file.It works but calling the files from Vi.lib on every step. For the reference i am sharing the couple of images.
Thanks & Best Regards.
(178 Views)
Regarding the first error:
go check the SequenceFilePostStepRuntimeError sequence in your sequence file. There seems to be a MessagePopup, which is upset with something
Second error: your StationGlobals seem to be missing the data field SoftwareConfig.Vendor
Did you happen to transfer your sequence to a different machine and forgot to copy over StationGlobals.ini?
(168 Views)
