NI TestStand
ERROR when trying to run Update VI Calls: object reference not set to an instance of of an object.
See picture below, Please help, Thank you.
(5,087 Views)
Resolved, I had a TS handled opened in the LV GUI. If I close all LV GUI, then it's fine.
(5,080 Views)
Another cause for this error "object reference not set to an instance of of an object" is if you have not logged into TestStand or have disabled Login On Start.
Go to Configure -> Station Options -> User Manager -> check box " Login On Start"
Close TestStand
Open TestStand and login
Update VI Calls will now work
(4,071 Views)
Your answer is helpful.
(3,916 Views)
