NI TestStand
ERROR1305 at deploying TestSTAND (acess to lvffrt.dll)
At deploying our developped application to a user station there is a problem shown at attached picture.
There is an error message :
Error 1305 Error reading from file c:\appl\National Instruments\Shared\LabView Run-Time\7.1\
lvffrt.dll
Verify that the file exists and you can access it.
Examin the file results that the installed file to disk is a little bit greater than the file in real
The same deployment tool has worked before at an other user station.
The application has been developped with TESTSTAND3.1(3.1.0.9095) and CVI 7.1.0
Does anyone have an idea to solve mentioned error.
(3,064 Views)
Are you getting this error when you are running the installer or when you are creating it?
Try copying the lvffrte.msm file to the <TestStand>/Redist directory.  It will be on your installer CD in the Redist directory.
Allen P.
NI
(3,046 Views)
