NI TestStand
Easy way to run test steps in parallel?
Hi, all,
I have a situation in which I need to verify that several things happen before different specified times -- and I also need to measure the actual times when they happened. Example:
1. Hit unit on processor with hammer
2. Verify that unit says "Ouch" within 3 seconds
3. Verify that unit sees stars in less than 10 seconds
4. Verify that unit has a lump on its processor in less than 60 seconds
Now, it could be that the events all happen, but not in the order I listed above. For example, it could see stars before it says "Ouch!" So if I assume a particular sequence of events and wait for them in sequence, my timing measurements will be inaccurate.
I know I can execute subsequences as new threads, but this seems extremely cumbersome. All I need to do is execute a set of test steps in parallel, and pass the entire test case if all the steps pass.
I don't think the parallel execution model will help, because this is a single UUT.
Is there an easy way to do this?
- Steve.
(3,548 Views)
If you are using labview then you can run a step using the LabVIEW Utility step 'Run VI Asynchronously'.
see Reference Manual Appendix E.
Regards
Ray Farmer
Regards
Ray Farmer
(3,545 Views)
Thanks, but it looks like there are a couple of problems with this approach:
1. The remote execution doesn't directly support a test (I could get around that by saving the flag value and checking it afterward, but I'd rather just run the test step directly);
2. Even on localhost, I'm a little concerned about extra overhead for remoting.
Any thoughts?
- Steve.
(3,543 Views)
A quick look at the code behind the Run VI Asychronously, it looks like its dynamically creating a Sequence and placing the LabVIEW to run in it.
If this is the case, then you might as well start of with you VI(s) in a Sequence contained in a SequenceFile and Specify the SequenceCall to run in a New Thread at edit time. This is easy to do, also it does allow you to call a sequence of steps rather than just one VI. It just depends on whether you want to call a series of simple LabVIEW steps  or one complicated VI.
The Static version (calling a SequenceCall step) does seems to have less overhead at runtime.
Regards
Ray Farmer
Regards
Ray Farmer
(3,533 Views)
