NI TestStand
Edit LabVIEW VI Call Missing Names
All of the sudden, when viewing the VI Parameter Table in the Edit LabVIEW VI Call, the Name column is missing and I can not expand any of the clusters. It's as though the COM/ActiveX link is somewhat broken.
I have previously configured many VI links using the Parameter Table and have mapped many individual cluster elements to TestStand items, but now I can not even expand the clusters (because the name column is completely missing) to view the mappings. Everything seems to run fine, and the mappings still seem to exist, but I can no longer view or edit them, and I can not see the name column for existing configurations or new ones.
Martin
(2,980 Views)
Hi Martin,
If you put your mouse in the area with the red mark, near Type, your mouse cursor will change.  Then, you can expand the name column, even though it is currently hidden.
Message Edited by AEDavid on 02-19-2007 11:44 AM
Cheers,
David Goldberg
Software R&D
(2,960 Views)
