NI TestStand
Edit "Edit Property Loader..." cause an ActiveX Error
Hello
I have just make a fresh install of TS 3.1f1
I have inserted a Property Loader step, and whenn I click on "Edit Property Loader..." button I get an ActiveX error:
sCode = 0xffffbc66, Description: Unknow variable or property name 'SequenceFile'. Error accessing item 'SequenceFile'.
Yannick Willener
(3,118 Views)
hi,
Can you call the
"\Examples\PropertyLoader\PropertyLoader.seq " and test this sequence? If you cann't run this sequence succsessfully may be you have to deinstall TS and install it again. If you run the sequence successfully than it seems that you have some problems with calling values through activeX. Check please the format of variables.
Regards
TN
(3,115 Views)
