NI TestStand
Enable Results Recording Programmatically
Hi everyone,
Is there a way to Enable Results Recording for a step programmatically?  I want to only show a step's results if the step FAILS.
Thanks so much!
(4,053 Views)
It sounds like you want to have the step in the report if it fails. If it passes (or is Done), you don't want to list it in the report. Correct?
If so, you don't want to meddle with result recording, but with report generation. You can configure this for HTML and ASCII reports directly in the report configuration (Result Processing >> Report Options).
Norbert
Norbert
Expert: Geometry
(4,051 Views)
