Hello Elaine,
What you are suggesting is not quite what I am after, as it only seems to affect the Report Generation.
I also need the result (and limits) to be encrypted at the test step stage, so that if anyone was to pause the program, they would not be able to look at the result and limit variable values and see the un-encrypted values.
I was thinking of having an de-encyption VI just before each test step that would de-encrypt the encrypted limits and pass them to the test VI and an encyption VI just after each test step that would encrypt the test results.
But, not sure the best way to do this.
As for the Report Generation, it would only be the results and limits that need to be encrypted.
So would be grateful for any suggestions.
G
erry
