05-18-2010 11:45 AM
When using the LabVIEW IVI drivers for PXI-4071 and PXI-2527, I receive an error -1074118625 in TestStand. The sequence initializes the MUX, init DMM, connects the MUX, waits for debounce, and then upon reading from the DMM, I receive this error.
Error: niDMM Read Waveform (waveform data).viExplanation could not be found for the requested status code.
[Error Code: -1074118625, User-defined error code.]
This sequence of events is successfully used multiple times elsewhere in the TestStand. This error does not appear in any knowledgebase article nor in any help. Any explanation would be greatly appreciated.
Solved! Go to Solution.
05-18-2010 02:36 PM
I found this with google that seems like it might apply:
http://digital.ni.com/public.nsf/allkb/A593DEBFD86A69C68625727900748EEC
05-18-2010 02:57 PM
05-19-2010 01:42 PM
