NI TestStand
Error 17004. Trying to load a dll on remote machine
I am trying to control a network simulator using a dll that is in a remote PC.
I run into this error 17004
I gave in C/C++ Module Path: \\<PC Name>\C\MX847010\Remote Library\RmtSvcLib.dll (this is accessible from the PC with test stand)
I also added \\<PC Name>\C\MX847010 in Search Directories
Has anyone faced this before?
Module for Step 'Open MNS' not Loadable. Could not load DLL or external library '\<PC Name>\C\MX847010\Remote Library\RmtSvcLib.dll'.
This DLL requires the following DLLs which could not be found or loaded:
MFC70.DLL (Not Found)
MSVCR70.dll (Not Found)
MSVCP70.dll (Not Found)
File        :
C:\Users\user\Desktop\Anritsu_testStandproto\MNS_500_IRAT_HO.seq
Seq["MainSequence"].Main["Open MNS"].TS.SData
Rule        :
Code modules must be able to load
Description :
TestStand must be able to load all code modules without error. TestStand reports errors at run time when it
fails to load a code module.  Correct this problem by editing the step in the sequence editor.
(3,422 Views)
It sounds like you are missing the dependencies that the DLL requires.  You need to have them installed on your computer.
(3,420 Views)
These look like Microsoft MFC files and I have Visual Studio already installed on my PC.
(3,418 Views)
