NI TestStand
Error -17306 Unknown variable or property name
I get the above error when trying to deploy from Windows 2000 to a Windows XP professional?
(4,289 Views)
When does this error occur?  What are you doing when it happens?
Are you trying to access a Station Global that is not deployed?
Allen P.
NI
(4,286 Views)
Allen,
I get the error after deploying  to new PC. I get the error as soon as I select " Test UUT's". I do not get the error on the development PC.
(4,282 Views)
Have you got the ProcessModel sequence file "SequentialModel.seq" on you Deployed system.
You should find it in "TestStand\Components\NI\Models\TestStandModels" folder or "TestStand\Components\User\Models\TestStandModels" folder.
Regards
Ray Farmer
Regards
Ray Farmer
(4,271 Views)
I am currently using a cutom model,  it is present in the Model directory.
(4,257 Views)
Do you know where the step is failing?  The error sounds like you are trying to reference a variable that does not exist.  Since it is only happening on deployment, you probably are referring to a Station Global variable that has not been deployed.  Try setting breakpoints in your model and step through the code to see where it fails.
Allen P.
NI
(4,249 Views)
