NI TestStand
Error -17600 in calling a LabVIEW RT VI which call a third-party driver
In my application, I want to launch a LabVIEW RT (7.1) VI from my TestStand (3.1) sequence, but when I execute the sequence (an example is the zip file), a -17600 error (a print screen is in the file) occurs.
My VI, which call a GOEPEL driver (for using a LIN network board) work perfectly from LabVIEW.
Have anyone met similar problem ?
(2,909 Views)
WarMarvin,
Same problem has already been met at the following links:
http://forums.ni.com/ni/board/message?board.id=280&message.id=1150&query.id=51283#M1150
http://forums.ni.com/ni/board/message?board.id=330&message.id=5234&requireLogin=False
Please tell us if these links doesn't solve your problem.
JPR
NIF
(2,885 Views)
