NI TestStand
Error 7 on deploy build
I am trying to do a deployment build in Teststand 3.1.
Whatever I try to build I get error log:
Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW error:
Invoke Node in TestStand - Dist Cmp Settings to Disk Hier.vi->TestStand - Build VI Distribution.vi->TestStand - Build VI Distribution AX Wrapper.vi->TestStand - Build VI Distribution AX Wrapper.vi.ProxyCaller
There are no broken VIs in what i am trying to build. The file TestStand - Dist Cmp Settings to Disk Hier.vi is a Teststand VI.
I have reinstalled the Teststand components from the install disk but still get the same error.
Any ideas?
Fiona
(3,114 Views)
Are any of these links any help to you, the first one is very similar to yours
here
or here
Regards
Ray Farmer
Regards
Ray Farmer
(3,108 Views)
