NI TestStand
Error 97 while running VI from TS2..
please your advice.
I running VI from TS2 and at the end i get
the atthached error (97). i dont see any problem
in the VI by using breakpoint and debug
please your advice
(3,164 Views)
Israelsze1,
We have a KnowledgeBase entry that addresses this question. Although this was written for TestStand 1.0 and LabVIEW 5 and 6, the same information applies to TestStand 2.0 and LabVIEW 7.0. This KnowlegeBase entry can be found by searching for "+teststand +97". The KnowledgeBase is the second result. You can also reach it by this link: KnowledgeBase 268A5NBD: TestStand Error Code 1 or 97 when using LabVIEW.
Hope that helps.
Shannon R.
(3,164 Views)
thanks, it works fine
(3,164 Views)
