NI TestStand
Error Code -17212
Hi community,
I have a ni-teststand project that my colleague has started and i suppose to continue to develop it mode and he/she sent me all the files in a folder and i have problems with opening the files. I got the message below when i try the open any file;
" Unable the open file 'C:\Users\...\myexample.seq'
Error code -17212,Path not found.
Source 'TSAPI'  "
I count find anything about the error -17212.
And by the way i am a copmlete newbie in teststand. I read about deployment utility and it is not clear for me that deployment utility should be used when a project is done with develoing and relocate to test station or deployment utility also can be used when we want to relocate a project.
My friend just send me his/her project folder. Nothing like an installable image of and project whatsoever.
I attached the error -17212 screenshot below.
Thansk in advance for your ideas and help
(3,013 Views)
Make sure you have that particular file in your system directory.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,973 Views)
