NI TestStand
Error connection SQL DB
Hi I usaully used Access mdb to store test result. Now I have installed SQL 2008 express (show picture). But I cannot create the UUT_Results database. I tried from the SQL Server Management studio, but I cannot find the master (*.mdf).
I tried also from the TestStand --> Configure --> Database Option --> DataLink tab --> Build.
In "Provider" tab I select SQL Server native Client 10.0
In "Connection" tab I do not know what insert in SPN Server. (show picture).
When I try to select the form the menu "3. Select the database" it returns error (show picture).
Any suggestion is appreciated.
(3,634 Views)
Hi logatto,
Your SQL server should be: SEML-ECAVALL\SQLEXPRESS
Have you tried this with an empty SPN server?
Steve
(3,576 Views)
