NI TestStand
Error in Engine callback does not get handled by PostStepRuntimeError
I've been unable to find any threads addressing this issue. I'm overriding the SequenceFilePostStepRuntimeError engine callback in a client sequence file. I'm also overriding a few other engine callbacks like SequenceFilePreStep and SequenceFileLoad.
The issue that I'm running into is that if a runtime error occurs inside of the the engine callbacks (i.e. SequenceFilePreStep) then the SequenceFilePostStepRuntimeError callback does not handle the error and it resorts to using whatever station option I have set (e.g. shows the error dialog box)
What (if anything) can be done to have the SequenceFilePostStepRuntimeError callback handle errors that occur in other engine callbacks?
CTA, CLA, MTFBWY
(3,137 Views)
Did some more searching and found this. Any other ideas?
CTA, CLA, MTFBWY
(3,135 Views)
Look in the TestStand reference manual in chapter 10 under Caveats for Using Engine Callbacks:
5th bullet point!
For your entertainment only:
http://forums.ni.com/t5/NI-TestStand/I-am-stunned-by-TestStand-suport-engineer-s-answer-to-my-bug/m-...
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,128 Views)
Don't feed the trolls, jigg 😉
CTA, CLA, MTFBWY
(3,124 Views)
