NI TestStand
Error in Labview-teststep when using Runtime-adapter
i am using Labview and testand version 2022.
I have a problem executing a sequencefile with a labview-teststep that calls a DLL-function.
Direct under Teststand the teststep executes normally with Labview-Adapter = Runtime (autoselect)
Running the same in my custom c# opui  i get the attached error popup.
But when i switch to Adapter= Development, then it is working.
What can be the problem here?
Thanks for help
Message 1 of 15
(2,973 Views)
attached the detailed log from the error message.
When i remove the DLL from the VI then the teststep is running.
When i call only the dll as Donet-step then the dll is also running
But the error appears when executing a sequence with the VI containing the dll and running in runtime-mode
Message 2 of 15
(2,961 Views)
Does you C# OI happen to call the same DLL?
LabVIEW calling .net modules can be a PITA when using assemblies outside of the GlobalAssemblyCache (GAC).
Where is the dll located in respect to the calling VI?
Message 3 of 15
(2,947 Views)
Yes, this dll is only oe time on the computer
The DLL is in a subdirectory below the VI.
The DLL is found from the  VI via the searchpath defined in labview at Tools->Options->Path->VI search path
Also in Teststand this path is defined.
Message 4 of 15
(2,944 Views)
Would you mind trying with the DLL in the same directory as the VI?
Message 5 of 15
(2,941 Views)
No difference 😞
(I moved the DLL to same location then opened the VI which notices the new location. Then saved the vi)
Message 6 of 15
(2,938 Views)
Is the D Drive you are using a "real" drive or a mounted folder? If mounted... which method are you using for mounting?
Message 7 of 15
(2,935 Views)
It is a real drive.
Message 8 of 15
(2,932 Views)
Thanks for clarifiying!
So.... the sequence-editor is "just another" OI which is actually accessing the same API calls you C# OI is.
Have you tried using one of the example OIs that come with TestStand? Maybe we can get a hint where the difference lies
Message 9 of 15
(2,923 Views)
It is working with the this UI:
C:\Users\Public\Documents\National Instruments\TestStand 2022 (32-bit)\UserInterfaces\Simple\CSharp\TestStand 2022 (32-bit) C# Simple UI
Message 10 of 15
(2,920 Views)
