NI TestStand
Error in formatting by command line the cRIO 9068
I tried to format a cRIO 9068 by command line following this discussion but this error appears:
umount: /mnt/userfs/run: target is busy.
/etc/init.d/mountuserfs stop failed with 0 (attempt 30)
ERROR: /etc/init.d/mountuserfs stop failed (30 attempts)
*** Error: /usr/local/natinst/bin/nisystemformat:186 (fn=umount_rootfs): Unexpected status code 1
(safemode) admin@NI-cRIO-9068-Name:~#
I also tried to format using MAX but with this error
Do you have any suggestion?
Riccardo
(1,717 Views)
same identical problem on MAX and on command line (for the same cRIO model too!).
Did you solve it somehow?
(1,562 Views)
Suggest you to post this in hardware related forums and not in TestStand.
Maybe here :
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
Ravi
(1,557 Views)
I solved using labview 14 and related software to format and reinstall the cRIO OS. Then, I upgraded the system to labview 19
(1,551 Views)
