NI TestStand
Error in installing TestStand 2012
I am seeing strange error while installing TS 2012. The attached files shows the error. My system has P4 processor with 2 GB memory and Win XP is the OS. Please help me in installing TS 2012.
(2,969 Views)
Installer Error 1106 are caused by misconfigured system files within the OS if I am not wrong. You could try this:
http://www.almuseo.com/1106-error.php
Before that, also try the alternate setup.ini file provided. Replace your setup.ini with this and try the installation.
(2,948 Views)
