NI TestStand
Error in step: instrument reserve (-6 user defined code)
I'm doing the training couse of teststand.
Could anybody help me with this error please?
Thanks so much.
Message 1 of 10
(5,402 Views)
Hi cristina.lopez,
this happens when the reference to the instument has not been properly closed.
When this error occurs, select Run Clean UP instead of Abort to make TestStand close the opened references properly.
Message 2 of 10
(5,368 Views)
I still have the Problem. I tried just to run the clean up , but does not work. Could you share how did you solve the issue with me please?
Message 3 of 10
(4,935 Views)
I have the same problem, can anyone help with it?
Message 4 of 10
(4,903 Views)
Did you highlight the Close DMM step in the Cleanup and then run Selected Step. Don’t run the whole sequence.
Regards
Ray Farmer
Message 5 of 10
(4,898 Views)
Do you have a Soft Front Panel for the device open? Or do you have a test panel in MAX open to the instrument?
If you aborted your TestStand sequence with an open session, it is possible that the resource was leaked. Try restarting LabVIEW and TestStand.
If none of that works, try rebooting the computer. The resource is clearly tied up somewhere, but a reboot is quickest way to recover.
If it does not work after a reboot, then the system is in a really bad state, and you should try working with the device in MAX to verify it functions normally.
- Regards,
Beutlich
Message 6 of 10
(4,892 Views)
In the setup step of the main sequence, you have initialised DMM, Power supply and Scope.
Add value for DMM out = FileGlobals.Instruments.DMM
Power Supply out = FileGlobals.Instruments.PowerSupply
Scope out = FileGlobals.Instruments.Scope
Re-run the main sequence, and everything will be OK.
Message 7 of 10
(4,888 Views)
I got same error , but it is resolved by changing Power supply reference from "PowerSupply" to "Power Supply".
Message 8 of 10
(4,302 Views)
I got it! I've been struggling with the same thing for a few hours.
The Initialize DMM is working fine. Its the Shut Down DMM that is not functioning properly for me. The "Synchronization" in the Shut Down DMM needs to be set to "Serial (one thread at a time)" or it will only close the first instance and future runs will fail.
PS: You may need to open the Shut Down DMM VI and use it on DMM0 and DMM1 before this fix will take effect.
Message 9 of 10
(3,604 Views)
Hi All,
    struggling a bit as well I found the solution )as posted in the other similar thread:
  • the error I got was
Driver Simulation.lvlib:Handle Errors.vi
Instrument name not found. Ensure that you called initialize for the instrument name.
(Additional Information)
Instrument Name: PowerSupply
  • Solution
In the Step Settings part, you need to be sure that the VALUE is set in the same way, so if you choose "PowerSupply" you need to be sure that all the 3 steps "Initialize PowerSupply", "Controller Board Thermal Test" and "Shut Down PowerSupply" have the "Power Supply in" Parameter Name set to "PowerSupply".
Hopefully, this can help to clarify and solve the issue.
Have a great time with TestStand
Message 10 of 10
(1,388 Views)
