NI TestStand
Error in variable report
I've been making some changes to my sequence and now I keep getting the following error (please see picture). Could you please help me determine what could be causing it?
Thanks in advance
(483 Views)
Well, usually rolling back changes one by one helps you to find out 😉
The TestStand File Diff/Merge Tool is your friend!
The error message says that you have a type-problem; probably with one of the parameters of the call.
(445 Views)
