NI TestStand
Error launching the 'LabVIEW.A​pplication" ActiveX automation server [Error Code: -18001]
I have TestStand 2010 and LabVIEW 2010 development systems.
In the TS LabVIEW adapter is configured to use Development System.
Till today everything worked properly.
Today I tried to run TS sequence (which worked yesterday) and got error -18001.
I changed LV adapter configuration to use LVRTE and then back to Development System - and got error -18001 again.
Please see the image below.
LV2010 development system exists and I can use it: edit and run VIs.
How can this problem happen and how to resolve it?
Thanks in advance!
(3,228 Views)
there are multiple possible causes why you could encounter this error. Have a look in this KB:
http://digital.ni.com/public.nsf/allkb/5C692ACB049D0D30862575710051601F
cheers,
cheggers
Sascha
(3,199 Views)
Cheggers, thanks for reply!
I already solved this problem. There was something wrong with registry permissions. Probably, I changed it today by mistake, while trying to solve a problem caused by another program. 🙂
(3,197 Views)
Fortunately you remembered your registry changes... else it would not be easy to troubleshoot 😉
Sascha
(3,194 Views)
