NI TestStand
Error loading Step
Hi all,
I have an issue when a execute a sequence file in sequence editor.
this is the error message :
"Error calling sequence. Error loading step 'MyStep' of sequence 'MainSequence' in file 'Sequence File.seq'. Could not find file ''.
Error Code: -17208, File or directory not found.
Source: 'TSAPI'
The error happens immediately after clicking on "start"
MyStep is a custom StepType developed by myself. It calls a .NET code module.
I can edit the sequence and Step.
Have you got an idea about this error?
Thanks in advance for your help.
(3,298 Views)
You need to add a search directory to the location of that file.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,268 Views)
Have you put your StepType in the User file area?
Regards
Ray Farmer
(3,266 Views)
Accepted by topic author maxmont
Thanks for your help.
I found my mistake.
I set adapter as .NET but I don't have code module to call.
So, TS try to get an empty class from an empty assembly.
I set adapter as None and it's working.
(3,248 Views)
