NI TestStand
Error logging results to database in TestStand
I am attempting to configure a distrubted TestStand application to log results to a MS Access database and I get the following error:
"An error occurred in the 'Open UUT Result SQL Statement' step of the 'Log UUT Results' sequence in 'Database.seq'.
Error executing substep 'Post'. Automation error code -2147352573 0x80020003
Member not found.
User-defined error code. Error Code: -12"
I followed all the steps in the TestStand User's Manual to link to a MS Access database. I have successful linked to Access databases on other machines following the same steps. However, I have tried everything on this machine and I still can't get it to work. I have reinstalled MS Access as well as TestStand and my distributed applicatio
n.
I am using TestStand 1.0.1, Win NT 4 service pack 5, MS Access 2000.
I tried to install MDAC version 2.1 as suggested in the discussion below, but I got a message saying that my system did not support the installation of that version of MDAC.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000FC540000&ECategory=TestStand
Any help would be greatly appreciated.
Kevin
(3,510 Views)
Kevin -
I do not know why this happens on this one system. I can tell you that the -12 error is an ODBC Driver error being returned to the LabWindows/CVI SQL Toolkit that the Database step types use. The toolkit is a wrapper for the ADO ActiveX server that comes from MDAC. The member not found error states that the wrapper is attempting to access the server and when asking the server for the ID of a method, it says that it does not exist.
I assume that MS Access is having to problems accessing the database but it does not use ADO, but instead uses DAO which is a different library than MDAC.
If there is any way to uninstall/reinstall MDAC, this might help.
Do you know what version of MDAC is on the system? Microsoft's website ususally has an standalon
e application that you can download to help figure this out.
Scott Richardson
Scott Richardson
https://testeract.com
(3,510 Views)
Scott,
Thank you for your suggestion. It was very helpful and I was eventually able to solve the problem.
I went to the microsoft website and downloaded the Component Checker which is a utility for diagnosing MDAC installations. It told me that I had MDAC 2.5 installed. The MS documentation on the web claimed there was some means within Component Checker to uninstall or rollback MDAC 2.5, but I could not find any and the documentation circularly referred to itself for the instructions, which were no where to be found.
Ultimately, I manually deleted every DLL associated with MDAC 2.5 (as listed by the Component Checker utility). Then I installed MDAC 2.0, which is included in the TestStand 1.01 software. After reboting and reconfiguring the test results
database, the problem was solved.
Kevin
(3,510 Views)
Kevin -
I am glad it worked. TestStand 1.0.1 is an older version. I believe that some of our components that use MDAC had to use the generic interfaces exposed by MDAC 2.0. Starting with MDAC 2.5 and later Microsoft had to rework their interfaces in an attempt to allow for use of its new version and future versions, but this caused problems for some components compiled against MDAC 2.0. These components needed to be updated to reference the version specific interfaces to better handle these version changes but I do not this that we caught on to Microsoft's changes until TestStand 2.0. TestStand 2.0 uses MDAC 2.5.
Scott Richardson
Scott Richardson
(3,510 Views)
