NI TestStand
Error message when Specify Module is selected
When "Specify Module" is selected for step using .NET adapter I got the following error message:
.NET Error:
Could not load file or assembly 'mscorcfg, version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f11d50a3a' or one of its dependencies. The system cannot find the file specified.
(3,147 Views)
What version of TestStand? Is the step you select specified to call something? What happens if you insert and select a new .NET step?
-Doug
(3,137 Views)
