NI TestStand
Error occured when using runtime engine instead development system
First, my system :
TestStand 2016 (16.0.0.185) 32-bit
Labview 2013 (13.0.1f2) 32-bit
I've got some VIs which are working fine when i run them alone.
I would like to sequence them with TestStand.
Second, my issue :
In the window "Adapter Configuration" when i choose "LabView Development System" , i'm able to run my VIs without problem.
But when I choose "Labview Run-Time Engine" (with "auto detect using VI version" activated) I've got an error (see picture attached).
I can't understand why it's doing this. My VI that I call is simple. I do no have entry parameters. Only one error out (see attached).
I tried different runtime engine. In those cases i've got a classic error (like error : -17600) which is normal.
Do you have some ideas please ? Thank you
(2,105 Views)
There are several things that can cause this error.  Some things to try:
  • Check your search directories (Configure->Search Directories). Ensure the VI and its subVIs are covered in the search directories.  Note that you may need to check the box for "Search Subdirectories"
  • You may have changed a subVI and you need to resave any other VIs that call that subVI.
  • There's a known issue with having TestStand calling projects in instr.lib.
Pulido Technologies LLC
(2,086 Views)
