NI TestStand
Error reading an ActiveX Automation server - DIAdem 64bits
I am using NI TestStand 2016 32-bit and DIAdem 64-bit on a PC with Windows 10 Pro 64-bit, when I try to use an ActiveX/COM action and when I select the Automation Server: DIAdem (Ver 1.0) the following error is displayed:
An error ocurred reading an ActiveX Automation server type library.
Error Code: -18351
[Refer to "Error 18351.jpg"]
I have the same software installed in another PC and here is working well, but here in the Automation Server appear as DIAdem (64-bit) (Ver 1.0)
[Refer to "ActiveX working well.jpg"]
I have tried to reinstall all the NI software and also I tried the following links, but I cannot fix the issue.
https://forums.ni.com/t5/NI-TestStand/Activex-error-after-launching-the-execution-on-Test-stand-erro...
Any Idea? In advance thanks  for the support?
(2,321 Views)
(2,142 Views)
