NI TestStand
Error: test uuts calls this before looping on UUTs. Is empty in Model file. Override this in the client file to perform an action before any UUTs are tested
Hi all
I  have slightly modified the   SequentialModel.seq file  so I can loop on Preuutloop Callback  &  have skipped "Handle Termination"
although in a rare instance it gave me this error
highlighted in png  file
(4,747 Views)
Hi aparab,
I don't see any error in the png. The "Handle Termination" is skipped as mentioned in the settings. If you don't need it at all, you can simply delete it.
Or did you get any specific error? Could you maybe explain to me what you thought was the error?
Regards
(4,656 Views)
Hi ,
i suspect that my modified seq-model file is the reason for error
the png is my modified seq file.
bcos i have never got this error mentioned in the subject -  with testand default seq file.
regards
akshay
(4,648 Views)
