NI TestStand
Error using Labview runtime and FPGA
Hi all. I noticed I am getting a error -18002 when I try and run some FPGA code I developed in LabVIEW 2015 when I use the runtime adapter in TestStand 2014. It is strange because the code runs on the first iteration of my test loop and then on subsequent iterations appears to run but throws an error. The error seems to suggest that the VI is broken/missing dependencies so I tried compiling it into a packed library and then calling the packed library but that made no difference. Has anyone hit this problem before or got any suggestions? Many thanks, Andy
(3,315 Views)
Hi ATEandy
There is a KnowledgeBase article that addresses the issue that you are currently experiencing. The link can be found below:
Error While Loading LabVIEW VI with the Run-Time Engine Adapter in TestStand
http://ae.natinst.com/public.nsf/web/searchinternal/2c12b0fbd1a61c358625810e004d04f9?OpenDocument
Kind regards,
Christian
(3,279 Views)
Hi Christian, the link you posted does not seem to work? Is there a typo in it?
Andy
(3,269 Views)
Hi Andy,
Apologies, I believe that was an internal version. I've attached the link to the published version.
http://digital.ni.com/public.nsf/allkb/2C12B0FBD1A61C358625810E004D04F9?OpenDocument
Kind regards,
Christian
(3,266 Views)
