NI TestStand
Error while accessing custom step type DotNetEventHandler.dll
Hello Community,
I used the custom step type for .Net events aus described in
https://forums.ni.com/t5/Example-Programs/TestStand-NET-Event-Handler-Step-Types/ta-p/3527170
For no good reason it stopped working and displayes following Errors:
When executing/configuring the step:
Error: Error executing substep 'Post'. / 'Edit'.
Error loading DLL - It may have been blocked by Windows because it was downloaded. To unblock it, right-click the file in Windows Explorer and click "Properties." Click "Unblock" at the bottom of the Properties dialog.[Error Code: -17600, Failed to load a required step's associated module.
I tried to unblock the .dll, but there is nothing to unblock.
The same setup on another machine is working perfectly fine. Windows version is the same (Version 1709 Build 16299.492).
I was using TestStand 2014, now updated to 2016, no change.
Has anyone seen this before?
Thanks for all replys.
Kind regards
Henry Reger
Student, Wilo SE, Germany
(2,444 Views)
Hi Henry!
Please, can you tell me, does your issue still persist ? Please, let me know.
FH
(2,379 Views)
I don't know why, but the problem is gone and everything is working properly now.
(2,372 Views)
