NI TestStand
Error while initializing TestStand Deployment Utility
(second PC from my other post)
Win11 TestStand 2022 and 2023 (Same error).
Tried uninstalling and reinstalling.
Tried installing TS2023
attached log has no useful information
(1,111 Views)
seems like the attachment was striped.   this is the contents of the TSDU detailed status log.xml
<?xml version="1.0" encoding="utf-8"?>
<?xml-stylesheet type='text/xsl' href='C:\Program Files (x86)\National Instruments\TestStand 2023\Components\Stylesheets\TSDU\TSDULogViewer.xsl'?>
<tsdu_log_messages xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="www.ni.com/TestStand/DeploymentUtilityLog/1.0 tsdulog.xsd" xmlns="www.ni.com/TestStand/DeploymentUtilityLog/1.0">
<deployment build_status="not_built">
<log_message time="2024-08-02T10:26:33.4983522-04:00" severity="Process" code="19400" phase="Edit">
<message>Starting a log for the deployment. Feature toggles were set successfully.</message>
</log_message>
<log_message time="2024-08-02T10:27:22.7648502-04:00" severity="Process" code="19400" phase="Edit">
<message>Shutting down.</message>
</log_message>
</deployment>
</tsdu_log_messages>
(1,095 Views)
Has no one run into this error before?
(1,047 Views)
