NI TestStand
Error with deployment of DBLog
Dear Sir,
I use TestStand 3 with Oracle. I have no problems with the development station.
I have build a deployment package using the build-in tool, and I get the following error on the production station:
An error occurred calling 'LogResults' in 'ITSDBLog' of 'DBLog 1.0 Type Library'
Database logging uses the NI Session Manager server to manage shared database connections. A call to create the Session Manager failed. Please verify that this ActiveX server is properly registered.
-2147221164; User-defined error code.
Possible System Error: Class not registered
Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
I have try to register the dll by hand (regsvr32 DBLog.dll) but it doesn't fix the problem
Yannick Willener
(3,675 Views)
Yannick -
The NI Session Manager server is C:\Program Files\National Instruments\Shared\Session Manager\NISessionServer.dll. See if this is installed and that the DLL is registered properly.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,675 Views)
Scott,
I have copy the Session Manager directory from my development station to the test station and register NISessionServer.dll by hand. It is working now.
How to tell the Test Stand deployment utility to do this job?
Yannick Willener
(3,675 Views)
Yannick -
For TestStand 3.0 we incorrectly included the session manager only when IVI step types are installed. For our next release we will include it as part of the engine.
Scott Richardson
(3,675 Views)
I found this error.
please set this as ANSWER or KUDO this post, if it help you.
(1,842 Views)
