NI TestStand
ErrorMessage when defining .Net Teststep
i wanted to create a ".Net"-PassFail-Step and added it in TS3.5. But when i click on SpecifyModule i get the attached error-message.
What is the problem here? I just installed the current Framework 3.0
(After clicking on OK the normal interface to define the Step pops up to select dll, class and method.)
Thx for your help.
(3,237 Views)
Looks like TestStand is expecting the Framework 2.0.
Have you tried installing the framework 2.0?
Does the dialog work normal after klicking ok?
(3,226 Views)
It actually looks like you are missing the .NET SDK.
This forum post has the same problem you are.
http://forums.ni.com/ni/board/message?board.id=330&message.id=10519&query.id=60589
Allen P.
NI
(3,223 Views)
It was the missing SDK. Now everything works.
Thanks for the help
(3,216 Views)
