NI TestStand
Escape characters in variables
I have a an array of strings local variable Locals.Header. Each element should contain TAB characters, so I created these strings as they would be in expressions - where \t is a tab character after evaluation of the expression.
If I build a string with the STR() function from the array elements, all "\t"s appear in the print. But I need tabs. What is the reason and how to solve it?
Madottati
(4,343 Views)
This forum post should help you:
http://forums.ni.com/t5/NI-TestStand/TestStand-Handling-special-characters-in-expression-strings/td-...
However, you have an array of strings.  This is a little cumbersome, but I made a For Each Loop where I use the Unescape function for each array element.  Take a look at the attached example.
Pulido Technologies LLC
(4,322 Views)
Use "\\t" instead of "\t"
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,308 Views)
