01-23-2009 03:39 AM
Hello...
is there a chance to evaluate two Message PopUps into a IF-loop?
The program should continue, if the "OK" buttons of both Message PopUps were pressed.
Otherwise the program jump to the end.
Patrick
Solved! Go to Solution.
01-23-2009 03:52 AM
Hi Patrick,
Put only one popup into a seperate Sequence. Just call your Sequnces in a new Thread. And wait for these theads in a Wait Step
Now there should be two MessagesPopup on screen at the same time.
Hope this helps
juergen
--Signature-- just click on the star a see what happens --Signature--
