NI TestStand
Evaluation of results in main sequence
Can anyone help me.
I have a sequence that consists of several subsequences each of them with several tests and also subs with there tests. Also there are some test and evaluations in MainSequence. I want to evaluate the status before finnishing  MainSequence to do some extra tests on fail.
I
know that I can access the Parameters.Result.Status from PostUUT. But is there a parameter that can used from MainSequence?
I have google and found the following suggestions.
RunState.SequenceFailed
thisContext.SequenceFailed
ThisContext.RunState.Main.SequenceFailed
Does anyone knows if any of them works in my case?
(1,061 Views)
So, you did some investigation, have you tested which of the approaches works?
Using breakpoints and checking the variables pane can help a lot!
At least one of your suggestions works IMHO 😉 so go ahead, try and learn😊
(1,031 Views)
I will go with RunState.SequenceFailed and hope it will work in any situations
(1,010 Views)
