NI TestStand
Ex 5-2b Simple OI.cws solution from TestStand II course CD doesn't work
The solution files for Ex 5-2b Simple OI.cws included in the TestStand II customization course CD doesn't convert the 1D array sent from the TestStand ActiveX step correctly. With other words, the values converted from the ActiveX object to scopeMeasurementData (in CVI) are not correct values if compared to values Locals.Waveform in TestStand. How to succeed with this conversion ?
I have course manual and CD for TestStand 3.0 September 2003 edition.
Petri
(2,974 Views)
There is a mistake on page 5-54 in the manual. The screenshot is incorrect. When you set your UI Message, set the activeXDataParam to Locals.Waveform rather than ThisContext.
Hope this helps!
Allen P.
NI
(2,953 Views)
